Radio will not come on. Need help with determining the problem.
check your fuses.
I check the fuses, all seem ok. Is the radio difficult to replace?
check your fuses.
Actually pretty easy to replace, Do you have any idea what caused the failure ?
Yea, either it's the fuse or your radio is dead. It cant be anything else
Toyota Wheels
Can't ? Well it could be a connection failure, Dirty fuse contacts, Possibly an amp issue, Or just the power switch on the headunit ............
