Here here:
Do I go with Eibach and OEM or Eibach and KYB? I am not looking for race type handling..just a little more than stock? Will I get a little more with the Eibach drop or do I need Eibach and KYBs.
Post responses.
if you want just a bit more than the KYB's might be what you are looking for since they are a bit stiffer than stock....so response in exchange for rare persian silk smooth :lol:
OK....I am now leaning to the stock struts with the Eibach springs...any comments before I order my parts which I plan to do in a few days. Any problem with the Eibach/OEM set...for example will I blow out the bottom of the struts?
1997 no air suspension
OEM will do the be fine. Is KYB the only option you have?
For that year, Monroe sensatract and Bilstein and then jump to coil overs. I beleive that the Bilsteins are going to be to stiff. Monroe? Coil-overs- outside my budget.
