How To Replace Headlight Assembly Lexus Ls400 1992
andre
hello,
have a problem changing a bulb in a driving light :((
i can not remove the assembly , after udoing 2 screws
what should I do next ?
I dont want to break anything...
how many screws are holding the assembly ?
URGENT ! ! !
hello,
URGENT ! ! !
If you have an owners manual handbook instructions are there. I have had to change both of mine.... its easy. There are actually three bolts and a nut that have to come out. You have to take out the side marker light as well to gain access to the ones on the outer side.
One bolt is on the lowest part of the inside of the light... the other is above the fog light, the other is on the lower right side... then there is a nut above that has to come off.
