elacesar Posted August 29, 2009 Share Posted August 29, 2009 Hello i think I previously mentioned a noisy motor on my RX300 a few weeks ago and I found out that it was the flexpipe that seems to be a common problem with these.. I received the pipe two days ago from RockAuto and it was an exact fit. If you do change yours make sure you order the gaskets because they are not included and mine were in pieces so i had to run out and get them.. I am writing here because after installing the flexpipe I started the car and the noise was gone BUT i noticed some smoke coming up for a little while and I wanted to know if this is normal. I know that it is a brand new pipe but I wanted to make sure before I do anything else.. Thanks all for any help.. Quote Link to comment Share on other sites More sharing options...
jgr7 Posted August 30, 2009 Share Posted August 30, 2009 I would say it is normal, the heat is just burning off any residue from manufacturing. Jeff Quote Link to comment Share on other sites More sharing options...
Domenico Nelli Posted April 13, 2010 Share Posted April 13, 2010 "If you do change yours make sure you order the gaskets because they are not included and mine were in pieces so i had to run out and get them.". So are there two conical shaped exhaust crush gaskets for that pipe? How much did you pay for the intermediate pipe? Thanks :) Quote Link to comment Share on other sites More sharing options...
