Slight Vibration At Startup And Suspension Noise While Turning
sgretchko
1997 LS400 with 167,000 miles. A couple of developing concerns:
First, when starting in the morning I get a little vibration from the engine area. It lasts a few seconds and then everything is smooth. It may be time to do engine and transmission mounts.
Second, a high pitched "shuttering" (I hate to call it grinding) seems to come from the front suspension when turning slowly.
Any thoughts or ideas? Thanks.
Yep, at 167K, probably needed. The tranny mount (at least on the 1990-94 LS) is super easy and cheap to replace, so start there and see what happens. It eliminated alot (but not all) of my vibration, but my car has 222K. I know the engine mounts are bad, but I cant afford that now.
That steering shudder dont sound good. Is the fluid level OK? Sounds like your rack is going, but I dont know. Just a guess.
Good luck.
