Lock Problem
HunterXRen
Hey guys,
I have a 04 IS300 and the driver side door lock does not seem to work with the key transmitter. Every other door works except the driver side, I have done research on forums and it seems like my door actuator is busted. I was wondering if you guys knew the part number or knew which car from the Toyota company has the same exact one as the IS because I would prefer to get it at the toyota dealership rather then the Lexus stealership. Lexus quoted $165 for the part, I am sure if I could purchase it from Toyota it would be way cheaper. Thanks in advance!
