imfamous t Posted July 28, 2009 Share Posted July 28, 2009 aiite their is 95 sc400 wit 125k on it the guy says the fuel pump is bad he says it the only thing wrong wit it wat should i look for and wat kind of common prob does it hav can anyone giv me some tips and suggestion on it including how much would it be to rebuild the tranz and engine Quote Link to comment Share on other sites More sharing options...
grnsc40095 Posted July 28, 2009 Share Posted July 28, 2009 This link has a list of common problems with the Sc. http://www.intellexual.net/faq.html Quote Link to comment Share on other sites More sharing options...
Sc400=Delirium Trigger Posted August 4, 2009 Share Posted August 4, 2009 aiite their is 95 sc400 wit 125k on it the guy says the fuel pump is bad he says it the only thing wrong wit it wat should i look for and wat kind of common prob does it hav can anyone giv me some tips and suggestion on it including how much would it be to rebuild the tranz and engine Well for starters when the turn the key into the start position (without evening cranking the motor) you should be able to hear the fuel pump running. Pop the trunk and put your head near the trunk lining behind the rear window the fuel tank and pump is right there. If you can hear that most likely its working. If not then it is either a fuel pump problem or the fuel ecu (did I say that right?) which can be bypassed very easily and is a 30 minute fix that cost nothing. Rebuilding the trans and engine.. ehh sorry man but no idea here. Good luck! Quote Link to comment Share on other sites More sharing options...
