ryan_h Posted July 3, 2009 Share Posted July 3, 2009 This one is a bit odd. I walked out to my 2002 ES300 the other day, pushed and held the door unlock button to open the windows and sunroof.... front windows went down, sunroof opened... but BOTH rear windows stayed up. I got in the car and tried to push the interior switch- they may the small noise (almost a very faint click- same as all other windows in the car and on my older ES) that they do when they first open (the mechanical noise of the motor requesting the windows to go down), but the rear windows don't go down. Same thing happens if you push the window buttons in the back seat - slight, normal noise, and no window movement. Is it not odd that seemingly both motors would go out on the exact same day at the exact same time? I don't think thats possible... I haven't checked the fuses yet, but correct me if I am wrong, if the fuse was blown I would hear NO Noise from them .... Please advise :) and thanks in advance. Ryan Quote Link to comment Share on other sites More sharing options...
gbhrps Posted July 3, 2009 Share Posted July 3, 2009 ryan_h, I don't think that you have any blown fuses or window motors that have gone bad, as they wouldn't both give up the ghost at the same time, unless hit with a power surge. Guessing here, but do you have the window lockout switch on the driver's door pushed down? The only thing that might not fit with this idea is why the passenger front window went down but not the two rears as well. You may have a lockup somehow in the remote's radio receiver that controls the alarm, immobilizer, door locks and windows. I would wonder if disconnecting the battery for 5 minutes would somehow reset it. Its worth a try. Keep us posted! Good Luck! Quote Link to comment Share on other sites More sharing options...
zockslexus Posted July 5, 2009 Share Posted July 5, 2009 ryan_h, I don't think that you have any blown fuses or window motors that have gone bad, as they wouldn't both give up the ghost at the same time, unless hit with a power surge. Guessing here, but do you have the window lockout switch on the driver's door pushed down? The only thing that might not fit with this idea is why the passenger front window went down but not the two rears as well. You may have a lockup somehow in the remote's radio receiver that controls the alarm, immobilizer, door locks and windows. I would wonder if disconnecting the battery for 5 minutes would somehow reset it. Its worth a try. Keep us posted! Good Luck! no responses bother me. if this guy ever checks back here...i would agree with dude above..plus start looking in your owners manual for odd things of this nature. Quote Link to comment Share on other sites More sharing options...
SW03ES Posted July 5, 2009 Share Posted July 5, 2009 Try slamming both rear doors with the engine on and then try the windows again. Sometimes the rear windows jam, and slamming the doors resets the motors. I had this happen to my driver's side rear window last year and just by accident I found it worked after a client got out and slammed the door overly hard. After talking with others on here I learned that the slamming serves as a reset procedure. Quote Link to comment Share on other sites More sharing options...
ryan_h Posted July 6, 2009 Author Share Posted July 6, 2009 I will have to try disconnecting the battery & NO! I do not have the lockout switch activated :). Thats the first thing I checked! Ha... Sorry for no response... I have been on vacation :). The door slamming idea, while novel, and completely understandable did not work as I figured it wouldn't because of my luck. Will update as soon as I have tried something new :). Quote Link to comment Share on other sites More sharing options...
ryan_h Posted July 7, 2009 Author Share Posted July 7, 2009 Okay, I lied... I can confirm that the doors needed slamming harder WITH THE ENGINE ON :) because it sure as H*LL didn't work with the engine off! Thanks! Quote Link to comment Share on other sites More sharing options...
zockslexus Posted July 7, 2009 Share Posted July 7, 2009 Okay, I lied... I can confirm that the doors needed slamming harder WITH THE ENGINE ON :) because it sure as H*LL didn't work with the engine off! Thanks! glad to see that it worked!! sweet! Quote Link to comment Share on other sites More sharing options...
SW03ES Posted July 8, 2009 Share Posted July 8, 2009 Yep, gotta leave the engine on. Glad it worked! Quote Link to comment Share on other sites More sharing options...
mikemeehan7 Posted August 4, 2009 Share Posted August 4, 2009 Try slamming both rear doors with the engine on and then try the windows again.Sometimes the rear windows jam, and slamming the doors resets the motors. I had this happen to my driver's side rear window last year and just by accident I found it worked after a client got out and slammed the door overly hard. After talking with others on here I learned that the slamming serves as a reset procedure. Thank you so much for this info!!! I also had to hold down the window button as I slammed the door with the engine running but my window now works!!!! Thanks again for the info Quote Link to comment Share on other sites More sharing options...
SW03ES Posted August 5, 2009 Share Posted August 5, 2009 Just had to do it again on my car... Quote Link to comment Share on other sites More sharing options...
