The other day when I got home I stopped the car and after putting the trans in park, shut down the engine. A "beeping" sound went off for about 5 seconds while the key was in the ignition. I'm sure this is something simple like..... I left something on and its reminding me to do something. A little help in this matter from you experienced Lexus people.
That sounds like the sunroof tilt warning. Double check that your sunroof is completely closed.
Thank you. The sunroof was barely open. Just enough to trigger the alarm.
My 97 LS doesn't beep when the sunroof is open. An option mine doesn't have?
I'm not sure about a 97, but on my 90 the warning is only for the tilt. If I slide the sunroof back and turn off the car, no warning. However, if I tilt it up and shutdown, then I'll get the beeping.
yeah, on my 90 it beeps if you leave it open. I often do because I park it in the garage so I know the sound. Mine beeps if the sunroof is not fully closed.
