Dreamwalker Posted June 18, 2009 Share Posted June 18, 2009 Hey guys, I am new to this forum but plan to contribute as much as possible. I own a '95 sc400 with 150k miles, Injen intake and grounding kit. This topic I am discussing how to replace the rear sway bar links. Difficulty of Job- Beginner/intermediate *Recommended tools/setup -Socket wrench w/14mm socket -Channel lock wrench -Jack and jack stands -beer -crowbar Step 1. Jack the car up either on just one side or both. Step 2. Use the 14mm socket wrench to loosen the nuts on the link. Step 3. Use the crowbar to depress your swaybar, this will help you remove the link. Step 4. Depress the swaybar and put in the new link, continue to depress the swaybar while you tighten the nuts so you dont rune the links thread. Step 5. Drink your beer because yea its just that easy. * Not sure what the specs are for how much torque on the link nuts, I tightened them pretty hard but didnt over do it. (Sway bar link location) (Sway bar link) (Sway bar link removed) (New sway bar link) http://i870.photobucket.com/albums/ab268/B...usRepair010.jpg Quote Link to comment Share on other sites More sharing options...
grnsc40095 Posted June 19, 2009 Share Posted June 19, 2009 Dreamwalker, Nice work, all DIY with pictures/steps are welcome, thanks you for posting. Quote Link to comment Share on other sites More sharing options...
