tim john Posted June 8, 2009 Share Posted June 8, 2009 Hello, I have a 04 es, 62000 miles, should I have maintenance on the air conditioning even if its blowing cold air, and how about drain and flush on the radiator? never had that done yet. thanks. Tim Quote Link to comment Share on other sites More sharing options...
camlex Posted June 8, 2009 Share Posted June 8, 2009 A/C is closed system. No maintenance. Newer coolant goes up to 90,000. When you do your TB, WP etc. Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted June 8, 2009 Share Posted June 8, 2009 You could change the coolant a little early, I personelly think the maint schedules are more of a marketing speal, and not totally realistic. You will not hurt the car by doing it sooner than they recommend.The ac is a closed loop system, but you do have a cabin filter that should be changed, and the condenser fins should be checked for obstructions. Generally you can just backwash them to clean stuff off. BE CAREFULL AROUND THE CONDESSOR treat it gently while cleaning. Quote Link to comment Share on other sites More sharing options...
camlex Posted June 8, 2009 Share Posted June 8, 2009 Hello George, How to make condenser fins straight. Mine is 12 yrs older. That is will helps. Quote Link to comment Share on other sites More sharing options...
tim john Posted June 8, 2009 Author Share Posted June 8, 2009 Thanks, I do the maintenance by the book, checked the cabin filter, looks good. thanks and have a good day. Tim Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted June 8, 2009 Share Posted June 8, 2009 Hello George,How to make condenser fins straight. Mine is 12 yrs older. That is will helps. They have a tool, that looks like a comb, has several different sides to it. Each side is for different fin "Densities" that will straighten the fins and also dig out any hard core Kamikaze bugs. Quote Link to comment Share on other sites More sharing options...
camlex Posted June 8, 2009 Share Posted June 8, 2009 Thanks, Let me ask one more question for Sienna. same 1MZFE Engine. When minivan is cold no problem. after comes to operating temp., if you stop on stop light or sign and if you move your steering wheels to right at some vibration you feel on steering wheel. nothing happen on left turing. any idea? minivan has 140K. Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted June 8, 2009 Share Posted June 8, 2009 Check out this ebay auction, it gives a good picture of what I am talking about. AC A/C Radiator Condenser Fin Straightener Comb Rake FREE SHIPPING! Evaporator Coil Fins Cleaner Tool NEW! ebay Item number: 270389993116 Quote Link to comment Share on other sites More sharing options...
camlex Posted June 8, 2009 Share Posted June 8, 2009 Thanks, I found it @ NAPA for $9.99. Any advise on Sienna? Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted June 9, 2009 Share Posted June 9, 2009 Thanks,I found it @ NAPA for $9.99. Any advise on Sienna? seiena_steering.pdf There are several tsb's on your sienna. I think that this might be the most relevent for you car. Does it sound like this is what you are experiencing? Quote Link to comment Share on other sites More sharing options...
camlex Posted June 9, 2009 Share Posted June 9, 2009 Thank you very much. Any idea how much money to replace? Again, Thank you for taking time out and guide me in right direction. Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted June 9, 2009 Share Posted June 9, 2009 Glad to be of help. I have no clue on what the cost would be, my guess that it would not be too bad, (but probably a dealer only item). Quote Link to comment Share on other sites More sharing options...
