Sexus ES300 Posted June 3, 2009 Share Posted June 3, 2009 98 es300 Over the past few weeks the air bag light has been flashing sometimes when i drive. I looked in the manual and it said something about sensors needing to be replaced. Has anyone had this problem before? cost? diy? Heres the light thats flashing: Quote Link to comment Share on other sites More sharing options...
homemechanic Posted June 3, 2009 Share Posted June 3, 2009 the flashing sequence is equivalent of giving you an error code. for example, Code 43 flash-flash-flash-flash (long pause) flash-flash-flash. a very short pause in between each flash and a long pause between each digit. you can probably find out what the error code is telling you online or here on this site. btw, why u think it's the sensor? Quote Link to comment Share on other sites More sharing options...
Sexus ES300 Posted June 3, 2009 Author Share Posted June 3, 2009 It said somewhere in the manual that it could be a sensor or something il look later to clarify Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted June 3, 2009 Share Posted June 3, 2009 Run the diagnostic as described in this doc. Quote Link to comment Share on other sites More sharing options...
homemechanic Posted June 4, 2009 Share Posted June 4, 2009 i think you really need to read that blinking code to solve the problem. be worry free, airbags don't go off when you get that light stay on. however, your airbags would NOT deploy in an accident. if u believe it's the sensors behind the bumper, then you have to locate the short or determine if the sensor is bad. if it's the fail safe sensor inside the airbag computer, the entire computer must be replaced. that blinking code will give tell you which sensor or malfunction issue of the airbag. Quote Link to comment Share on other sites More sharing options...
Sexus ES300 Posted June 4, 2009 Author Share Posted June 4, 2009 So how do i run the diagnostics? All i got out of that picture was a wiring diagram Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted June 5, 2009 Share Posted June 5, 2009 Under circuit description, the last sentence tells which terminals need to be shorted together to place it in diagnostic mode. The light should start flashing the codes. Quote Link to comment Share on other sites More sharing options...
