Solace Posted May 25, 2009 Posted May 25, 2009 I have read through other threads about the steering wheel locking up while the car was parked or stationary, so please don't recommend that I read those post. I was driving a 2001 RX300. I was on turning in one of those U-turn lanes on I-35, the car was in motion when the steering wheel locked up and would not unlock. I basically stopped the car and had to sit there w/my flashers on while car manuvered around me. Blessfully, I was on the access road of I-35 otherwise it might have been a major disaster. :o Some guys who stopped to help managed to get the steering wheel to turn the other way, but it locked up again. We just drove it into the ditch to get it off the road. 1. Has this ever happened to anyone else while the car was in mothion? 2. What was the remedy? 3. What was discovered to be the cause? Thank you, Solace
code58 Posted May 25, 2009 Posted May 25, 2009 I have read through other threads about the steering wheel locking up while the car was parked or stationary, so please don't recommend that I read those post.I was driving a 2001 RX300. I was on turning in one of those U-turn lanes on I-35, the car was in motion when the steering wheel locked up and would not unlock. I basically stopped the car and had to sit there w/my flashers on while car manuvered around me. Blessfully, I was on the access road of I-35 otherwise it might have been a major disaster. :o Some guys who stopped to help managed to get the steering wheel to turn the other way, but it locked up again. We just drove it into the ditch to get it off the road. 1. Has this ever happened to anyone else while the car was in mothion? 2. What was the remedy? 3. What was discovered to be the cause? Thank you, Solace Thank God it happened where it did. I'm glad for you that it WASN'T disastrous. I have read of it before, but never as convincingly as you. I don't have an answer for you but I hope you had that thing flat bedded to the nearest Lexus shop.
SKperformance Posted May 26, 2009 Posted May 26, 2009 If it is locking up the key cylinder pin is disengaging causing the wheel to activate the pin as if the key is removed from the cylinder tumbler. Try cleaning the cylinder first or go to a lock smith.
VBdenny Posted May 27, 2009 Posted May 27, 2009 that is a pretty serious thing to have happen. I have never heard of that before and don't like the sounds of it at all. Fill us in on details when you find out why.
Solace Posted May 27, 2009 Author Posted May 27, 2009 Well, here's the rest of the story: The car got towed back to the Lexus dealership and the lock mechanism was worked on. I also got a new key made and programmed because there was a lot of "play" between the key and the lock chamber (The key wiggled around in the shafts.). This is the explaination that the dealer gave of the repair work that addressed the steering wheel locking while the car was in motion: " The technician who had originally serviced the lock cylinder replaced the locking pin backwards, resulting in the steering column locking up while you were driving it. That was repaired and checked..." I'm hoping this will prevent the locking up issue while the car is in motion. It would seem that this kind of thing may need to be checked periodically. How often? I don't know. ...but it was quite unsettling to be sitting in a lane while traffic zipped around me. If I had have been on I-35 instead of the access road OR was towing something, the story might have been tragic. Thank you guys for your concern and suggestions. Solace
SKperformance Posted May 28, 2009 Posted May 28, 2009 So the car was previously serviced for a similar type of problem ?
Solace Posted June 12, 2009 Author Posted June 12, 2009 So the car was previously serviced for a similar type of problem ? To my knowlege, no. It was a trade-in and the mech was prepping it for sale. ..so he was maintenancing the key cylinder mechanism. From the what I have read on the forum, steering wheel lockups seem to be a common occurence. The mech probably knew that so he was checking that area out as part of the prep. Solace B)
Brian t Posted January 22, 2021 Posted January 22, 2021 I've got a 2001 RX300 the came into my shop it's got a steering wheel lock up while driving situation know they were it slow movement at slight rotation it's still locked up and the owner is quite concerned as I am I any more suggestions
