Cynical Posted May 25, 2009 Share Posted May 25, 2009 I had an interesting situation today with my SC. After installing my new speakers I went for a drive and all is well, I came and left again a few times everything was normal. Just about an hour ago I went out put my key in the ignition turn it and the EVERYTHING in the car turn on then within a half a second went dead. It seemed to die when I tried to start it, but EVERYTHING shorted out nothing worked not a single light, sound.....nothing, the engine didnt even have a chance to try and turn over. I took the key out and tried a few more times, but the entire car remained completely dead. I popped the hood checked the fuses, and not a single one was bad. For ****s and giggles I tried it again and the damn thing worked perfectly fine, BUT my steering wheel, Radio and clock were all reset.........its as if the battery was disconnected. I was under the hood for all of 5 minutes or so and didnt touch the battery at all. It is to dark for me to trouble shoot tonight, where should I start? Oh the battery and starter is less than a year old, I'm thinking possibly the alternator but for some reason that does not sound right to me. I really hope to god its not the starter, I will be *BLEEP*ed if it is seeing how it is the ONLY part I had Toyota repair for me. My thoughts are either Ignition Switch or alternator, what are your thoughts? __________________ Quote Link to comment Share on other sites More sharing options...
john denninger Posted May 26, 2009 Share Posted May 26, 2009 My thought is a bad ground. I would clean both ends of the ground cable and consider adding another. Quote Link to comment Share on other sites More sharing options...
dcfish Posted May 26, 2009 Share Posted May 26, 2009 I had an interesting situation today with my SC. After installing my new speakers I went for a drive and all is well, I came and left again a few times everything was normal. Just about an hour ago I went out put my key in the ignition turn it and the EVERYTHING in the car turn on then within a half a second went dead. It seemed to die when I tried to start it, but EVERYTHING shorted out nothing worked not a single light, sound.....nothing, the engine didnt even have a chance to try and turn over.I took the key out and tried a few more times, but the entire car remained completely dead. I popped the hood checked the fuses, and not a single one was bad. For ****s and giggles I tried it again and the damn thing worked perfectly fine, BUT my steering wheel, Radio and clock were all reset.........its as if the battery was disconnected. I was under the hood for all of 5 minutes or so and didnt touch the battery at all. It is to dark for me to trouble shoot tonight, where should I start? Oh the battery and starter is less than a year old, I'm thinking possibly the alternator but for some reason that does not sound right to me. I really hope to god its not the starter, I will be *BLEEP*ed if it is seeing how it is the ONLY part I had Toyota repair for me. My thoughts are either Ignition Switch or alternator, what are your thoughts? __________________ Remove and clean both battery terminals like if you think you just contracted a STD, Then follow the neg battery cable down to where it is bolted to the body/frame, Disconnect it and clean it also like the afformentioned..................... Quote Link to comment Share on other sites More sharing options...
