davidly555 Posted May 19, 2009 Share Posted May 19, 2009 i have a 95 sc400 and would like to know wat can cause my car to die out well i was going to work and restart up within 5hr and run fine can a transmission cooler cause it Quote Link to comment Share on other sites More sharing options...
cactuseater Posted May 24, 2009 Share Posted May 24, 2009 i have a 95 sc400 and would like to know wat can cause my car to die out well i was going to work and restart up within 5hr and run fine can a transmission cooler cause it Died out? Did the check battery light come on before this happened? It could be an Alternator/Battery problem. Check your system to see if it is charging. The battery could be shorting out as the unit becomes hot...thus the plates could touch. As it cools, the battery plates could separate again - and let you start back up. Sooner or later (actually sooner) you will experience a completely dead car. You should have 14V DC or more on the charge with a load on the car (headlights, AC). A voltmeter on the battery terminals will give you an indication of you are getting the proper charge. My 95 SC400 did the same thing, and this was the fix. Quote Link to comment Share on other sites More sharing options...
