I have a 2002 ES300. The driver's door will not lock or unlock when you push the lock/unlock button on the fob. All the other doors respond. Any ideas what this problem could be? Thanks.
Do you hear anything from the door actuator when you press the lock/unlock button on the door? Or is it just when you use the remote? If neither work, check for voltage (when pressing the button) at the actuator). There could be a problem with the wiring, or connectors. Do not assume anything.
