Moon Roof Drain Leak?
jfb93
Greetings, I'm new to this forum so please bare with me if this has been discussed before. I'm also new to the SC300. I just bought the car in Jan of this year and am starting to work on it. Interior needs some help. I removed the front seats to clean the carpet and found a puddle of water under the drivers seat by the rear heat vent. This was after it rained when the car was parked outside. The head liner is dry around the sun roof but I was wondering if the sun roof drain line runs into that area? That is, if there is a drain line. There was also water on the bottom of the drivers side door kick panel at the sill. I checked the door drains and they are all clear. The front carpet is dry but the water is collecting behind the rail where the seat mounts.
Any input would be appreciated.
Thanks, Fred
jfb93, The links may have the solution to your leaking problem? look at all post on subject matter, especially Post 16 in 1st link an Post 3 in the 2nd.
http://www.clublexus.com/forums/sc-400-300...elp-please.html
http://www.clublexus.com/forums/sc-400-300...nt-find-it.html
Thanks for the info, the links are very helpful. At least I know this is a rather common problem. I'll be spending some time tomorrow trying to find the cause.
Where are you located in Md? I'm in Baltimore. I also have a Supra and have a few friends with them around here. Good to compare notes on the cars and I'm always willing to lend a hand on projects.
