MikeMiel Posted April 8, 2009 Share Posted April 8, 2009 Hi, I just replaced my power steering pump and alternator a year ago, everything worked great. I checked my power steering level and it was low so I filled it up to the right spot. A few days later my power steering pump is not working it has NO power. I have to turn the wheel with LOT's of force and really tires you out if you don't move the car and turn at the same time. When I checked the fluid level, it was good. I tried to open the cap and turn the wheel left and right while the car was on. The fluid was bubbling but still nothing helped. When I turn the wheel all the way, it doesn't make any noise like it use to. I don't see any leaks either. Quote Link to comment Share on other sites More sharing options...
jzz30 Posted April 10, 2009 Share Posted April 10, 2009 it could just be another faulty pump. oh also what fluid did you use? Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted April 12, 2009 Share Posted April 12, 2009 Hi, I just replaced my power steering pump and alternator a year ago, everything worked great. I checked my power steering level and it was low so I filled it up to the right spot. A few days later my power steering pump is not working it has NO power. I have to turn the wheel with LOT's of force and really tires you out if you don't move the car and turn at the same time. When I checked the fluid level, it was good. I tried to open the cap and turn the wheel left and right while the car was on. The fluid was bubbling but still nothing helped. When I turn the wheel all the way, it doesn't make any noise like it use to. I don't see any leaks either. When you replaced the pump, did you clean out the rack solenoid? Quote Link to comment Share on other sites More sharing options...
