so im gonna get this one
http://cgi.ebay.com/Lexus-IS300-Radio-Inst...5QQcmdZViewItem
for the install kit
and a double din Pioneer AVH-P4000DVD
http://www.crutchfield.com/p_130AVHP400/Pi...tures_and_specs
is there a wiring harness or do i need to splice into the factory wires? i want to keep everything stock(amp and speakers), and just change the headunit.
i tried searching but i can't find any info about this
thanks!
You won't be able to use the stock amp. Your going to have to run new wires from the speakers directly to the head and bypass the amp, or get a new amp. The amp has a 12v switch. I've only seen 2v and 4v switches on most aftermarket preamps. And be careful with running directly to the stock speakers, as thier only 2 ohm impedence, and most aftermarket is 4 ohm also. You can do it, just be a bit more careful as you can blow the speakers alot easier.
Also, whatever you do, use painters masking tape on the side edges of the center console dash first. That plack plastic is like a rubberized coating and it scratches really easy.
