camlex Posted February 12, 2009 Posted February 12, 2009 Hello, All Camry wheels and Lexus wheels has 5X114.3 setting. which offset requires for 97 ES300.? I like 2007 Camry 8 spoke wheel. will works? Please advise. Thanks,
Lexodus Posted February 13, 2009 Posted February 13, 2009 My 97 stock 15'' wheels were a 45 offset - and my new 17'' wheels of an 07 ES350 are 45 offset as well. Hope that helps.
camlex Posted February 13, 2009 Author Posted February 13, 2009 Thank you very much. This one has 45mm offset 07 and up toyota camry wheel http://cgi.ebay.com/ebaymotors/16-2007-200...bayphotohosting and center logo fits perfectly. if you have picture for wheel please post it.
Lexusfreak Posted February 13, 2009 Posted February 13, 2009 This link might be of help cam... http://us.lexusownersclub.com/forums/index...showtopic=23887 Many 'Toyota' wheels should be plug & play & have the +45 offset as well.
camlex Posted February 14, 2009 Author Posted February 14, 2009 Thanks, I found 17X8 from lexus GS. will these fits ? and what size tires you needs? Thank you.
124via126 Posted February 19, 2009 Posted February 19, 2009 This link might be of help cam... http://us.lexusownersclub.com/forums/index...showtopic=23887 Many 'Toyota' wheels should be plug & play & have the +45 offset as well. Hi all, new to the forum and looking forward to buying a new to me used 2005 ES330. Since we have alot of snow in Toronto, Canada; I prefer to have a set of snow tires for the winter because of safety, better traction. I already have a set of 15" snow tires, so I am hoping to be able to use these on the future ES. Could someone verify if 15" rims from Toyota Camry (all models) 1992-up (5x114.3mm / 12x1.5 Lug-nut / 60.06mm Bore) will fit 2005 Lexus ES330? I don't know if the following info from the link above is still correct since it was last updated in 2005: Lexus ES300 1992-up (5x114.3mm / 12x1.5 Lug-nut / 60.10mm Bore) . What difference does a 60.06mm bore vs 60.10mm bore make??? Thanks in advance !
Lexusfreak Posted February 19, 2009 Posted February 19, 2009 Hi all, new to the forum and looking forward to buying a new to me used 2005 ES330.Since we have alot of snow in Toronto, Canada; I prefer to have a set of snow tires for the winter because of safety, better traction. I already have a set of 15" snow tires, so I am hoping to be able to use these on the future ES. Could someone verify if 15" rims from Toyota Camry (all models) 1992-up (5x114.3mm / 12x1.5 Lug-nut / 60.06mm Bore) will fit 2005 Lexus ES330? I don't know if the following info from the link above is still correct since it was last updated in 2005: Lexus ES300 1992-up (5x114.3mm / 12x1.5 Lug-nut / 60.10mm Bore) . What difference does a 60.06mm bore vs 60.10mm bore make??? Thanks in advance ! Welcome to LOC 124....nice to see another fellow Torontonian on the forum (although I now reside in St. Thomas, Ontario). I will be able to help you with your 2005 ES 330 search just so you know (I own the same car)......I have several excellent Lexus contacts so let me know before you buy (send me a PM of what exactly what your looking for). There is a good selection currently. Your 15" wheels should fit.....however as Steviej mentioned in another thread.....they might look small on the vehicle. I just bought a set of winter tires (Toyo Garit KX in the OE 215 55 17 size & a set of OE 17" alloys). One suggestion I have is to possibly sell your 15" wheels & tires on say Kijiji (you will get alot of hits if they are priced right) and find yourself a second set of 17 wheels for a set of 17" winter tires (which I can also help you with). Something to think about. But good winter tires do make a huge difference with the ES compared to all seasons.
