Wheel Interchange
17" wheels were neither standard or optional on the 92 ES300. Only 15" wheels came on the 92 ES. I wouldn't have any idea if those particular 17" wheels would fit on a 94 LS400.
16" OEM wheels from a 94 LS400 should fit a 92 ES300.
The two cars should have the same bolt pattern and any wheel that fits one should fit the other in that sense. The offsets might be different (depending on how different that could matter) and the stock wheel sizes are different but as long as you use tires that get the overall diamiter and width close to the stock tire it should be ok.
For example if the original rim and tires were 205/65/15 and you wanted to upgrade to 17's the option closest to stock would be 215/50/17 - the radius and circumf are almost identical. You dont want the radius to be very different from stock - there are many online calculators that can help you with this, here is one I use:
http://www.miata.net/garage/tirecalcold.html
