Hi there,
I have a Lexus rx300 1999, with the engine light is on. I used ODB2 scanner to scan my car and it tells me the code of P1365.
After I change all 6 ignition coils and spark plugs, the problem reappears on the next day with the same problem/code. After spending
lots of time and by luck, I found the problem (I used screw driver to hit the valve/sensor mounted on the engine head driver side)
and the problem disappear. I just don't know what the name of this part called. It's something called Variable Valve Timing (bank 2)
system or VVT controller Assembly.
If you know the name of the part, please let me know so I can order and replace it.
Thank you very much,
It's quite hard to recognize the part as you posted on the diagram. When I have a chance to bring my car to my friend's garage,
I will take a picture of it and post it on. It seems to be OK now, but I know it won't last long.
Thank you very much for your reply.
Thanks again,
I eventually find out what this call.
It's called Variable Valve Timing Sensor and Toyota part number is 90080-19014.
I hope If some one has the same problem, check this valve/sensor first before changing
ignition coils/ spark plugs.
Somehow, we need to think more than just the scanner tell us.
Regards,
PS. So many mechanics that I ask don't see this valve broken before. Even online search for this part does not exist, Why?
I used software Mitchell - OnDemand to find out.
Hey, thanks for the feedback, glad you got it fixed....
