Bulb Replacement
How many Jersey natives does it take to change a light bulb? j.k. Hope this link helps. It has DIY's from an older GS4 but it should be the same... surprisingly I've never had to change my brake lights yet... only the high stop ones...
http://bananags.grantham-international.com/
I like that... more than one! Thanks. By the way... NY'ker moved to NJ so tweak the joke..... still a good one
Does anyone know how to replace the bulb in the Driver's rear tail/brake light of a 2003 GS300?
Yes, undo the 2 caps on outside and use 10MM socket to take bolts a loose. Then you have to get behind the cloth fabric on the inside of the trunk right where the lights are and undo 2 more bolts behind the fabric. Then it just lifts right out. Less than 10 minutes to do it.
