Lexusing Posted January 4, 2004 Share Posted January 4, 2004 I had my wiper on high tonight and everytime it gets to the bottom. it hit something...like the stopper. It does not hit anything when it is on normal speed. It only does this when it is on high speed and on the down cycle. Any idea to solve this problem guys/gals? Please advise. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
Meist21 Posted January 4, 2004 Share Posted January 4, 2004 My guess is that because it was going so fast it actually was hitting on the bottom turn. You can adjust the wiper position by loosening the bolt holding the wiper down and lifting it up and slightly moving up one notch on the teeth that hold the wiper in place when the bolt is tight. Not sure what else is going on but that is my best guess. Quote Link to comment Share on other sites More sharing options...
RCRFAN3 Posted January 4, 2004 Share Posted January 4, 2004 Had the same problem with my 98LS400 after I had the windshield replaced. The driver side wiper is mounted too low on the spline for the wiper arm. Quote Link to comment Share on other sites More sharing options...
vevro Posted January 4, 2004 Share Posted January 4, 2004 I've had a problem with Bosch wipers, the smaller one on the passanger side was too high and was hitting the tip of my hood. Make sure this is not happening with your wippers. Quote Link to comment Share on other sites More sharing options...
Lexusing Posted January 6, 2004 Author Share Posted January 6, 2004 Thanks for all the replies.....I found that the second arm (there are two on the driver side) on the driver side was hitting the passenger side on the bottom cycle during high speed.....I am going to take Meist21's suggestion and do that when the weather is warmer...it's ing cold in Cols. OH even in the garage.....thanks again guys/gals. I will post the result when it is done. Quote Link to comment Share on other sites More sharing options...
