Help, anyone kinow where to get a replacement outside drivers door handle, new or used, for a 1994 LS400. mine broke yesterday.
** Moved to proper forum.**
Smooth 1
Here is one currently available on eBay.... LINK.
Thanks, I found one in Colorado for 65. and it was the right color.... you guys are a lot of help. cheers. bp
got it finished, was lucky to find one that matched the color..................
Billydpowell,
Where did you find it so cheap.. Everywhere they are over a hundred?
I need a silver one..
I used: aandrautoparts@aol.com
<aandrautoparts@aol.com>
talked to Mike.
I followed the tutorials here, on removing the door panel and replacing the handle.
yes it was easy, but BE CAREFUL, when you remove the relay rod, (I broke mine) dont prize on it, just work it loose. I broke the rod at the latch (it is made on to it) $400. from dealer, but I got a used one for $30, and it is a little harder to put in (without instructions) .
I have the old one and a couple of the "other" rods, if anyone needs them.
also "repaired" (made it workable) door handle, looked like sin, but worked, with a piece of metal I bonded to the underside of the handle.
have been tempted to do the new one this way for strength.
any way, good luck on yours.
sorry about my camera focus.... bp
