trilexus Posted January 2, 2009 Share Posted January 2, 2009 My lexus RX300 has trouble on brake light(The third light from the rear left). It will on when i push brake but it is not on when i turn on the light. In the meantime, the second light from the left is still work well. The brake light fail indicates on the screen. Could somebody help me? Thank you very much. Quote Link to comment Share on other sites More sharing options...
lenore Posted January 2, 2009 Share Posted January 2, 2009 are you talking about the brake light mounted on the hatch back door above the window? If so it is probably burned out, real easy to replace, just pull the plastic cover off the window surround on the top of the door. Then you will have access to the lamp. Quote Link to comment Share on other sites More sharing options...
BillyShaft Posted January 2, 2009 Share Posted January 2, 2009 Sounds like you are talking about a dual filament bulb...one that is on normally when the lights are on, and gets brighter when the brakes are applied. If so, consult your manual. It will tell you which bulb to get from your local auto supply place and how to change it. Quote Link to comment Share on other sites More sharing options...
trilexus Posted January 8, 2009 Author Share Posted January 8, 2009 Sounds like you are talking about a dual filament bulb...one that is on normally when the lights are on, and gets brighter when the brakes are applied.If so, consult your manual. It will tell you which bulb to get from your local auto supply place and how to change it. Hi there! Thank you very much for your help. I replaced it. However, the light is not on while it get brigh as second bulb when the brakes are applied. It may com from wire problem, isn't it? How can i find that one? (I bought the right bulb from Auto zone) Thanks Quote Link to comment Share on other sites More sharing options...
