Check Enginelight After Tune Uo
MKMD
****************1996 LS 400*************
Hi:
Changed the dist caps
Rotor
Wires
and plugs
All above OEM
The car starts ok BUT check Engine light on and Trac OFf light blinks.
Car also idling faster around 2
Any advice would be greatly appreciated
M Khan
There's a lot of posts here about the check engine light coming on after disconnecting the battery-It's a glitch, not a problem. Go to Lexls.com, I believe-he has a great tutorial to fix it. Mine is on-too lazy to fix it until the weather warms up. Not sure about the trac light...Best of luck.
the trac light is coming on in response to CEL. you need to get the code pulled for the CEL.
http://www.lexls.com/tutorials/
i had same issue after a whole tune up and timing belt change. it was an O2 sensor. theory is the new plugs/wires/rotor, etc. got that part of car up to spec and the old/lazy orig O2 sensor did not react as needed.
