iana Posted December 21, 2008 Share Posted December 21, 2008 Can someone explaine the function of the ECT snow switch. I live Canada and this year we have alot of snow. I have a 2008 AWD RX350. Quote Link to comment Share on other sites More sharing options...
Messerchmidt Posted December 22, 2008 Share Posted December 22, 2008 Can someone explaine the function of the ECT snow switch. I live Canada and this year we have alot of snow. I have a 2008 AWD RX350. Use it only in the winter, and from a stopped position. I find that I get less wheel spin using it, and also slide less; it seems to do something to the torque split between the wheels which works well in snow. Quote Link to comment Share on other sites More sharing options...
Messerchmidt Posted December 22, 2008 Share Posted December 22, 2008 Can someone explaine the function of the ECT snow switch. I live Canada and this year we have alot of snow. I have a 2008 AWD RX350. Use it only in the winter, and from a stopped position. I find that I get less wheel spin using it, and also slide less; it seems to do something to the torque split between the wheels which works well in snow. works even better with actual snow tires.... Quote Link to comment Share on other sites More sharing options...
iana Posted December 22, 2008 Author Share Posted December 22, 2008 Yes I do have 18" winter tires on. how important is it to engage from standing start. I have noticed that if it is engaged going up a hill with 2500 rpm's and I engage the snow switch the rpm's will drop to below 2000rpm's and stay at the same speed with more control. from a standing start the rpm's will stay lower. I am happy with the results. Quote Link to comment Share on other sites More sharing options...
jgr7 Posted December 22, 2008 Share Posted December 22, 2008 Using the ETC Snow switch forces the transmission to start in 2nd gear. This stops the 1st gear wheel spin on a slippery surface. Jeff Quote Link to comment Share on other sites More sharing options...
GSY Posted December 22, 2008 Share Posted December 22, 2008 Is there a speed limit to which ECT should not exceed? Thank you in advance. Quote Link to comment Share on other sites More sharing options...
jgr7 Posted December 24, 2008 Share Posted December 24, 2008 Safe for conditions is the speed limit!!! Quote Link to comment Share on other sites More sharing options...
