I recently had the 700 dollar climate control replaced and my A/C was working fine and my heater too. About two weeks after it got really cold and I tried to use my heater, but only cold air would come out when i truned the climate knob all the way to hot. If I press auto at a temp that requires a heater, the fan does not blow and the climate control displays that there are no bars to indicate how hard the fan is blowing. What could be the problem?
I broke down and had lexus do the diagnostic for 91 dollars but I found out that the problem was that I need to replace the heater control valve.
Does anyone have the procedure to do this or can anyone send me a copy from the repair manual for a 1992 lexus sc300.
please send to rpgriggs@ucdavis.edu
I used to send out that stuff and still do for what I have digitized. But my scanner is done for. Unless someone else can do it for ya. I know at least one member here has done it before.
Heater control valve located on the firewall. This is an easy job. It would take you about 30 minutes.
www.jpimportz.org
