dwulffusa Posted December 10, 2008 Share Posted December 10, 2008 I have a collegue who has an 07 IS250 with the sport kit. She drives very gently and needs to get better mileage than 15-20k miles out of a set of tires. The current tires are On the front: Turanza - ER33 225/40 R18 88Y On the back: Turanza - ER33 225/40 R18 95Y I wanted to recommend a lower speed rating tire with longer life. Any recommendations. Do these vehicles have spares or runflats? thanks Quote Link to comment Share on other sites More sharing options...
dwulffusa Posted December 10, 2008 Author Share Posted December 10, 2008 I have a collegue who has an 07 IS250 with the sport kit. She drives very gently and needs to get better mileage than 15-20k miles out of a set of tires. The current tires areOn the front: Turanza - ER33 225/40 R18 88Y On the back: Turanza - ER33 225/40 R18 95Y I wanted to recommend a lower speed rating tire with longer life. Any recommendations. Do these vehicles have spares or runflats? thanks Correction 255 on the back Quote Link to comment Share on other sites More sharing options...
bartkat Posted December 10, 2008 Share Posted December 10, 2008 Continental Extreme Contacts are Z rated, have a high treadwear rating and don't really sacrafice much in handling. They're also pretty quiet. I've got them on my IS 350 and like them very much. Quote Link to comment Share on other sites More sharing options...
Manolo1 Posted December 11, 2008 Share Posted December 11, 2008 If long tread wear is important: H-rated: Michelin Energy MXV4 Plus Goodyear Assurance TripleTred Kumho Solus KH16 V-rated: Michelin Pilot HX MXM4 Michelin Pilot Exalto A/S Michelin Energy MXV4 Plus Others to consider if winter grip doesn't matter: H-rated: Continental ContiProContact Michelin Pilot XGT H4 Bridgestone Potenza RE950 V-rated: Yokohama Avid V4s Falken Ziex ZE 512 Bridgestone Potenza RE950 Quote Link to comment Share on other sites More sharing options...
Rafiki Posted December 13, 2008 Share Posted December 13, 2008 For maximum tread life you need to get a set of non-directional tires so you can rotate them. I replaced the OEM tires with a set of Nitto INVO tires. They are extremely quite, and non-directional so I can rotate them side to side. My set has 24K miles on them and they are still very quite. I estimate 35 - 40K tread life based on the wear so far. Handling is good. I inflate them to +4 psi over the recommended pressure. This gives me similar handling response to the OEM tires. Take a look at the Nitto INVO tire, I like them and will buy another set when it time to get new tires on my IS250. B) Quote Link to comment Share on other sites More sharing options...
Randy&Bonnie Posted December 14, 2008 Share Posted December 14, 2008 .. Quote Link to comment Share on other sites More sharing options...
Tbone76 Posted December 15, 2008 Share Posted December 15, 2008 New to the forum here, and instead of starting a new thread that may have been semi redundant, I thought I would just add to this one. I just bought an 06 IS 250 AWD. As much as I love the look of the low profile tires that are on them, is there another tire that will add more tread life as well as soften up the ride a touch. I know it is also a sport suspension and it still a darn smooth ride, but is there a better tire to make the ride a bit better and longer tread life (which I think was answered above)? Thank you in advance for your replies Quote Link to comment Share on other sites More sharing options...
bartkat Posted December 15, 2008 Share Posted December 15, 2008 New to the forum here, and instead of starting a new thread that may have been semi redundant, I thought I would just add to this one.I just bought an 06 IS 250 AWD. As much as I love the look of the low profile tires that are on them, is there another tire that will add more tread life as well as soften up the ride a touch. I know it is also a sport suspension and it still a darn smooth ride, but is there a better tire to make the ride a bit better and longer tread life (which I think was answered above)? Thank you in advance for your replies Yes as mentioned above the Conti Extreme Contacts will give that to you. Quote Link to comment Share on other sites More sharing options...
Hurrijeff Posted December 21, 2008 Share Posted December 21, 2008 When my Potenzas wore out around 20K I switched to the Michelin Pilot sport PS2's and I absolutely love them! They are way quieter, they seem to roll easier, they are wearing nice and slowly (estimating 25K out of them before replacement) and they are more responsive IMO. The Potenzas were not a bad tire at all but they got awfully noisy during the last 5K or so before I dumped them. Quote Link to comment Share on other sites More sharing options...
