Mylesf7 Posted December 9, 2008 Posted December 9, 2008 Allllright fellas I posted this on Club Lexus and didn't really get any help... here's the rundown 1999 ES 300 265k on the clock Got a check engine / trac off light about a month ago first things I did: -changed spark plugs -replaced fuel filter -changed air filter -ran a bottle of sea foam thru a full tank of premium fuel still not fix... -scanned the car pulled a P1130 code -replaced ALL THREE 02 sensors.... car ran fine for about 2 weeks (still had check engine light) now the car runs like total a$$! VERY rough idle and periodically bucks and shudders while driving I was thinking it may be a vacuum leak or something but if I disconnect the battery for about 15 min or so then drive the car (check engine light goes off) it runs perfect for about 15 min then the light comes back on and it goes right back to running like dung.... ANY help is GREATLY appreciated! I'm at my whits end with this car!
patchy360 Posted January 14, 2009 Posted January 14, 2009 Allllright fellas I posted this on Club Lexus and didn't really get any help... here's the rundown1999 ES 300 265k on the clock Got a check engine / trac off light about a month ago first things I did: -changed spark plugs -replaced fuel filter -changed air filter -ran a bottle of sea foam thru a full tank of premium fuel still not fix... -scanned the car pulled a P1130 code -replaced ALL THREE 02 sensors.... car ran fine for about 2 weeks (still had check engine light) now the car runs like total a$$! VERY rough idle and periodically bucks and shudders while driving I was thinking it may be a vacuum leak or something but if I disconnect the battery for about 15 min or so then drive the car (check engine light goes off) it runs perfect for about 15 min then the light comes back on and it goes right back to running like dung.... ANY help is GREATLY appreciated! I'm at my whits end with this car! Are you sure you got the right O2 sensors put in. They all are very similar for the 99es300. I also had a problem similar to yours, and had to get the O2 sensors replaced. It was a headache because I kept on receiving the wrong O2 sensors. They all look similar. Check out if you got the right ones
