Car On, Will Not Move...
maria g
Lexus sc400 starts no problem. Once on the road no problem. Until! when reaching a stop sign/light
the car will not move!!! It will still be on (in drive), the rpms go up when gas is pressed but won't budge...what the???
Had to park it, wait, and it works again.
Please help if this has happened to you before.
History of car:
Year 1992
Had radiator fixed early this year
Check engine light came on in October
Couldn't pass smog, paid 1000.00 for chk engine light code/repair
Soon after problem arose
When it does move does it ever feel like all of the power the engine is making is not getting to the wheels?
If so the torque convertor might be at fault.
If you take it to a shop make sure they agree with you on a price to just diagnose it. Cottman transmission is run by crooks that will disassemble the whole transmission, diagnose it, and then say "well...we have it all out and ready to fix so it will cost you xxxx to fix it but we can put it back in the car for xxx"
xxxx =ed $3100 in my MR2
xxx would have cost $1200
dose it move when you manualy shift it from first to second. if so then more than likely is is just a couple of solenoids in the transmission which can be easly changed. if it still dose not move then i would think clogged filter or torque converter.
