Which Line Level Converter?
Hi all
I'm in the process of upgrading my ML Sub by replacing it with a boxed JL W7 and separate amp. I've seen comments where some cheap Line level Conveters burn out. So for those that have made this upgrade, which Line level converter did you youse. I was looking at the JL Cleansweep, but it appears that it need a full range signal to work, and I don't think there is anyplace on the ML system to tap a full range signal.
Thanks
Buy a good amp like the JL 500/1 V2 and it has one built in.
I like the JL 500, and that would be a good idea except that I have an MB Quart and a Nakamici amp that I ran in my last car that needs to be put to use.
All of the line converters that I see are $50 or less and none are made by a company that is known for their quality.
