How To Change Oil Filter
I need help to change the oil filter on a 08 ls460, draining the oil seems easy enough but I cannot find the filter
Thanks
Here you go: http://www.clublexus.com/forums/showthread...s460+oil+change
You may need this to remove the filter: http://www.toolsource.com/toyota-lexus-fil...m-p-100298.html
Other part numbers: http://www.irontoad.com/Merchant2/merchant..._Code=2008ls460
Make sure you deflect the stream of oil draining from the pan AWAY from the protective shield, otherwise oil will flow into the "cover" and get all over the bottom of the car.
Good luck!
Hello:
The oil filter is in the likes of an Aircraft engine style. If they would use metal screen wafers, instead of paper, all you would have to do is clean them with gas and presto no waste. But mercantilism needs to be alive and well. C
