BlackLex Posted December 30, 2003 Share Posted December 30, 2003 I have a leak on my coolant reservoir can I repair or do I have to replace? My car is a 94 LS Quote Link to comment Share on other sites More sharing options...
wwest Posted December 30, 2003 Share Posted December 30, 2003 I can't believe the replacement cost could possibly be more that your DIY repair time. Quote Link to comment Share on other sites More sharing options...
BlackLex Posted December 30, 2003 Author Share Posted December 30, 2003 how about a little JB weld for plastic 5-7 Dollars. My time removing,aplying weld,reinstall= 1 Hr. 40 dollars an hour my time $ 47.00 total Resevoir - $130.00 + 45min. my time = $ 160.00 total Quote Link to comment Share on other sites More sharing options...
VBdenny Posted December 31, 2003 Share Posted December 31, 2003 My opinion is that the coolant reserve tanks is improperly marked. Try leaving you fluid a little lower when cold and it will probably stop leaking. This is fairly common in early LS models I think. whenever I fill mine to the cold mark, it leaks. If I leave it just above the low coolant senosr, it stays the same, doesn't leak, doesn't overheat, and works perfectly. Denny Quote Link to comment Share on other sites More sharing options...
BlackLex Posted January 3, 2004 Author Share Posted January 3, 2004 I noticed the same thing when I bought the car there was no leak and no coolant low light on. but as soon as I addedd a cup or so to bring it up to minimum it started to leak and the light came on for a min. or so I left it alone and the level went below the minimum about a 1 1/2" and it's not going any lower and now my light never comes on . I read another post weeks ago that said maybe there was air in the line. I drained the radiator and refilled but it did not help. I think I'll take your advice and do nothing .Like the old saying ignore it and it will go away. Thank you VBdenny!!! Quote Link to comment Share on other sites More sharing options...
