Po325, What Does It Mean?
PK_3
You may have a bad knock sensor or wiring. The wiring is under the intake manifold and could be shorting or breaking. The other possibility is bad gas causing poor running and the knock sensor to detect spark or timing knock. here is info on the knock sensor and wiring:
http://us.lexusownersclub.com/forums/index...sor+replacement
Ok, Thanks,
My OBDII alluded to that (knox sensor) At 80k though that seemed premature and a real pain. Makes a little more sense to check for faulty wiring to before I go hole hog.
Regards, PK
