My moms car...she called me tonight and said that her "Oil Light" (the little oil can deal with a drip coming out of it) has been coming on and off...I am not near her and dont have the manual in front of me...What is the common cause of this. I know the oil was changed less than 5k miles ago (probably around 2500-2750 miles ago)
Thanks,
Casey
Thanks,
Casey
maybe the oil is low?
Thanks,
Casey
could be leaking or burning oil. could have a faulty sensor. FIRST THINGS FIRST have her check the oil.....that way if it is low she doesnt lock up the motor. then check the sensor if it still comes on and off. i would be willing to bet she's low,leaking, or burning oil
had her check oil this morning...bout 1.5 qts low! Car has always been maintained well, I do the oil changes and always no more than about 4000 miles to a change...using Castrol 5-30 and a WIX wilter. Why might it be burning oil all a sudden??? Its definitely not leaking.
u sure u added enough last time? j/k but that is a possibility....she seeing any kind of smoke when driving? i think blue is oil or what they call blowby i think (im not sure but i think this is where oil is getting past the piston rings). im no mechanic, i can do enough to get me outta trouble but motor stuff i do leave to my 2 mechanics.....they great. can u check the compression across the board on the motor?
I'm also consuming what I consider to be a lot of oil... I suspect a VCG leak, but until i get around to looking at it I can't be sure... I need to add a qt about every 2500 miles...
  • Join The Club
    Join the Lexus Owners Club and be part of the Community. It's FREE!
  • Recent Achievements
    • yarlee earned a badge
      One Year In
    • AV Tech earned a badge
      One Month Later
    • rxmangriff earned a badge
      First Post
      Week One Done
    • GpaDan earned a badge
      First Post
