billydpowell Posted November 5, 2008 Posted November 5, 2008 1994 & 1997 headlight adjustment.. which way to turn the screws. up - down never mind... the 94 was easy, just 2 phillips and my garage door... 97 a little harder, small rachet + 8mm socket + moving some stuff out of the way & my GD again.... Cant figure out why no one offered any assistance or guidance.... oh well.....
Fickett Posted March 17, 2009 Posted March 17, 2009 Can you shed any light on the procedure for the '97? I worked the screws up and down as far as they would go on the mechanism with the level, but I need to tweak the passenger side much more than the measley adjustment that can be achieved with that method. I moved the air dam out of the way, and see the adjustments for L & R, but where are the bigger adjustments for up and down? Any tips or tricks would be much appreciated!
billydpowell Posted March 18, 2009 Author Posted March 18, 2009 Can you shed any light on the procedure for the '97? I worked the screws up and down as far as they would go on the mechanism with the level, but I need to tweak the passenger side much more than the measley adjustment that can be achieved with that method. I moved the air dam out of the way, and see the adjustments for L & R, but where are the bigger adjustments for up and down? Any tips or tricks would be much appreciated! The up & down adjustment was down low and recessed up in the housing. I found it by feeling it with my finger. the little socket and ratchet worked good. check this out: Lexus Headlight adjustment I have a '97 LS and just tonight finally figured out how to adjust the headlights. It is an easy DIY. Don't take it to your mechanic. I am assuming that a '96 has the same headlight setup as my '97. Anyway, this is what I discovered with the screws behind the headlight. My headlight aim left to right was fine, so I didn't have to adjust that, but I'll tell you how to do it just in case you need to do it. You will need a small 1/4 inch ratchet with an 8mm socket or something equivalent. I did this in my garage with an old towel hanging down in front of the headlight that I was adjusting. The headlights were on and I made a mark on the towel showing the top of the brightest part of the beam. That way I would know if the beam was adjusting up or down. Now, here's the riddle of the screws on the back of the headlight. When standing at the drivers side of the car, looking down at the back of the drivers side headlight, you will notice that there are two screws on the upper right side of the back of the headlight. One philips screw is embedded in a small gray round plastic cog. The teeth of this cog interlace with the teeth of a hex screw about an inch below it. This lower hex screw is the adjustment screw for left to right on the headlight. Turn this hex screw with your 8mm socket. Once again, this will adjust the headlight from left to right. Now for elevation adjustment. Like yourself, this is what has been bugging the out of me for some time now. Once again, standing at the drivers side of the car, looking down at the back of the drivers side headlight, you will notice another hex screw at the upper left side of the drivers side headlight. This will NOT adjust your headlight. I do believe it adjusts the fog light elevation, just FYI. Look below this screw and about 4 inches below it, toward the bottom left side, you will see another hex screw sticking out of a hole surrounded by black plastic trim. This is the headlight elevation adjustment screw. Turn it lefty loosy to raise your headlight beam or righty tighty to lower the beam. It will be a tight fit to reach this screw. I had to remove the battery hold down bracket for more room. Once you do this, adjusting the passenger side headlamp will be very similar except the position of the screws on the back of the headlamp will be reversed. Of course, to access the passenger headlamp, you'll have to remove the air cleaner assembly. cheers, bp I sold this bird in '04 1
