WANMAN Posted October 25, 2008 Posted October 25, 2008 :chairshot: Hello guys, I could really use a little help on this one. My SC400 92 started running really bad after cleaning the engine. I now not to do that again, but here is whats happen, the engine runs very sluggish when accelerating and idles at 1000-2000 rpm thats about 35-45 mph. When I come to a stop the car jolts forward revving the engine at 1000-2000 rpm. Also when I put it park or neutral it sounds as if I am pressing the gas with the engine surging up and down. I have replaced the MAF twice with used parts and continue to have the same problem. Have any of you experienced and or resolved this issue.
WANMAN Posted October 30, 2008 Author Posted October 30, 2008 Hey guys, its been a few days now and no one has replied to my post. I could really use your help is there any one out there that has experienced this problem. I had my mechanic look this error up in the online tech system called IDENTIFIX.COM and found that certified techs are saying this is a problem with the Idle Air Control Valve. Here's the catch, the parts cost is $650 - $726, that is outrageous for this small part. Anyone know were I can find an after market part or a used one?
UCF3 Posted October 30, 2008 Posted October 30, 2008 Try doing this first. Leave your car running idle for about 20minutes, if you're not getting the correct throttle pressure-right now. How's your fuel pressure?
WANMAN Posted October 31, 2008 Author Posted October 31, 2008 I have allowed the car to run for over 20 mins, but continue to get surging RPM. Actually when the car is cold it idles higher than normal about 1800 RPM then once the car warms up it tries to idle down then begins to surge at 1100-1700 RPM. It would really be nice to actually replace the correct part since parts for this vehicle can be be very expensive. Thanks
WANMAN Posted November 1, 2008 Author Posted November 1, 2008 Eureka! I have solved the problem, after cleaning my Idle Air Control Valve the car idled down and is purring like a kitten. Here are the details of what was done to fix the engine surge problem. After several days of research I was able to narrow down the potential problem parts. If your engine is idling high between 1000-2000 RPM these are the potential parts that must be tested for errors: the (MAF) Mass Air Flow Sensor, (IAC) Idle Air Control Valve, or Throttle Position Sensor. I recommend you purchase the Original Lexus Repair Manuals for further troubleshooting; there are 3 volumes well worth their weight in gold. OK, let's get to it... First and easiest part to test the MAF; see the attached MAF manual. If test fails replace MAF. Don't not use cleaners; they will make the car run worse. If the problem continues put the original MAF back in and go to next test. Hold on to the replace MAF just in case multiple parts are bad. Second, to test the IAC see the attached IAC manual If test fails try opening and cleaning ICA. The plastic housing contains and servo motor that can get corroded. Pay very close attention to the position spacer ring at the bottom of the IAC. It must be put back in on it back with the three wing pointed up. Clean and oil the motor with a small wire brush and 180 grit sand paper on gasket areas. Be careful not to use too much oil. If cleaning fails replace IAC Third, test Throttle Position Sensor To test the TPS see the attached TPS manual If test fails replace TPS Thanks and good luck!
dsb Posted November 1, 2008 Posted November 1, 2008 I have allowed the car to run for over 20 mins, but continue to get surging RPM. Actually when the car is cold it idles higher than normal about 1800 RPM then once the car warms up it tries to idle down then begins to surge at 1100-1700 RPM. It would really be nice to actually replace the correct part since parts for this vehicle can be be very expensive. Thanks wow man this is perfect timing my car is doing the same thing once it's warmed up idle surge from 1000-2000 where can i get a repair manual?? thx
UCF3 Posted November 1, 2008 Posted November 1, 2008 nice job. Thanks for the Pics. I'm sure it will come handy to someone.
twodmax Posted November 1, 2008 Posted November 1, 2008 nice job. Thanks for the Pics. I'm sure it will come handy to someone. I just had my 300 in shop and I will be replacing idle control valve. $700 ouch! They also want to clean fuel injectors for $150/ Is that normal? Car has 155.550 miles and runs great. They are master toyota lexus tech's.
WANMAN Posted November 6, 2008 Author Posted November 6, 2008 nice job. Thanks for the Pics. I'm sure it will come handy to someone. I just had my 300 in shop and I will be replacing idle control valve. $700 ouch! They also want to clean fuel injectors for $150/ Is that normal? Car has 155.550 miles and runs great. They are master toyota lexus tech's. =================================================== Twodmax, run you are about to get jacked. If you or a friend are some what handy you can clean this unit and save yourself $850. Read through my docs, you will find all you need to do this fix. Follow the test procedures to determine which part is bad. My Lex has 240,000 miles so this car just keeps going and going with the proper maintenance.
Opticsman25 Posted April 9, 2010 Posted April 9, 2010 Do you still have the MAF? I think my air flow sensor is going out on me. I would appreciated if you can sell me one of yours. Thanks, Pat
