Stuck In Park...is There A Fix?
rkruz
I have a LS400 1990, 240K miles. This morning I could not move the transmission lever from Park to Drive. Its stuck in park. Do you have any knowledge about what may be the cause and a fix you could pass on?
thank you!
It's most likely the switch on the brake pedal. I went through 2 or 3 of them in the 13+ years I had a 90 LS. You can shift out of Park by pressing the override switch button by the gear shift lever. Consult your owners manual.
