Thaddeus Posted December 26, 2003 Share Posted December 26, 2003 Hi, I am looking to replace my wife's old Volvo 740 and I am seriously thinking about buying an LS400, probably a 98 or 99, hopefuly with no more than 60K miles. I have some questions: (1) Are the bodies on these cars galvanized? i live in the salty north and I'll never buy a car again that isn't. (2) What regular maintenance should be done on these cars at around that range? tranny flush? timing belts? Other? What are the costs of these? (3) Is ther anything on these cars that is typical to go out? I've read some other posts and read some stuff about 90-94, are the 98-99's subject to any design flaws/ (4) Are there stiffer shocks/springs available to make the car handle more like, say, a MB or BMW, and can an owner install them himself? What are the sources for these parts? Cost? That'll do for now. Thanks in advance. Thaddeus Quote Link to comment Share on other sites More sharing options...
Lexus. Posted December 26, 2003 Share Posted December 26, 2003 (1) Are the bodies on these cars galvanized? i live in the salty north and I'll never buy a car again that isn't. >>>Yes. One of the strongest, rust-proof sheetmetals I've eve seen on a car (2) What regular maintenance should be done on these cars at around that range? tranny flush? timing belts? Other? What are the costs of these? >>>60K serv minor - oil change, air filter, spark plugs, brake fluid timing belt should be done at 90k (3) Is ther anything on these cars that is typical to go out? I've read some other posts and read some stuff about 90-94, are the 98-99's subject to any design flaws/ >>>No. They are last of the old body style (2001+ Ls430 true redesign), benefitted from 10 years of improvements and refinements. For example, gen 1 (90-94) have problem with instrument light going out, power steering pump leaking fluid over alternator, etc (4) Are there stiffer shocks/springs available to make the car handle more like, say, a MB or BMW, and can an owner install them himself? What are the sources for these parts? Cost? >>>Yes. Lextasy.com procarparts.com about 320 for lowering springs That'll do for now. Thanks in advance. Thaddeus Quote Link to comment Share on other sites More sharing options...
99lsguy Posted December 27, 2003 Share Posted December 27, 2003 60K service also includes: Coolant change, differential gear lube change, throttle body clean, minor ATF fluid change (pan drain of 2+ quarts), oil chnge, torque bolts to spec, PCV valve, inspect belts, air filter, cabin filter, etc.. Per Lexus, spark plugs are changed at 90K. Cost is $550 for dealer, $400 for import shop - KC, MO area prices.... Quote Link to comment Share on other sites More sharing options...
UCF3 Posted December 27, 2003 Share Posted December 27, 2003 98-99 LS doesn't have a ton of Aftermarket parts. The car is built correctly with slightly stiffer shocks and coilovers--to feel like the newer Beamers and Benz's. I suggest you test drive one, and put it through the cornering test. Since you live in a Snow Zone, be prepared to buy snow tires, if you're planning to drive it during. Since the car is for your wife, I would also suggest the ES, RX, and GS Series. They are all well designed cars. Quote Link to comment Share on other sites More sharing options...
Meist21 Posted December 28, 2003 Share Posted December 28, 2003 My 98 rocks. From everything I have been reading here the first gen models have their share of problems. I do not see a lot of issues with the 98. I researched well before I bought mine. The 99s had some electrical issues from what I read. The car is solid as a rock. Does not corner like a Benz but rides like a dream. Good Luck. Quote Link to comment Share on other sites More sharing options...
