2003 Es300
t&mlexus
After a drive, when the engine is cool enough to touch, slip your hand behind the rear valve cover. You're looking for oil. This is a common situation for these engines. The engine is mounted in a tilted way so the front valve cover is about horizontal and the rear one is leaned way back. After years, the valve cover seals dry out and leak. The rear sees all the leaking because it's tilted so far back.
The oil is running down the back of the engine and burning as it hits the exhaust. You may not see any dripping because it's burning, plus as soon as you stop the engine, this leak stops.
Changing out the VC seals is easy. Getting to the rear one is a whole production.
Good luck!
Good luck!
Thank you so much for sharing your knowledge..
