tsantoro Posted October 7, 2008 Share Posted October 7, 2008 How do I change the air filter on my 06 IS250 awd? Quote Link to comment Share on other sites More sharing options...
IS250_rookie Posted October 7, 2008 Share Posted October 7, 2008 I'll try to take a picture of the location. I'm pretty sure it's in the left bottom corner(when facing the front). There should be a big pipe coming from it. You will need to open the box with the filter inside. It usually has clips on it and sometimes requires some things to be disconnected in order to access it. Also you need to take the under-hood cover stuff off. Quote Link to comment Share on other sites More sharing options...
