Hey everyone,
My name is Gary and I live in the Houston, Tx area and I recently purchased a '92 SC400.
I haven't done anything major to it yet, other than R&R and a few small touches. The car had been sitting for over 3 years so there is quite alot to restore, but for $1500, I cant complain.
She just hit 250,500 last weekend and is still a pretty solid car with blown front everything.. and few other problems im working out
here are a few shots of it the day i got it.
I threw on my wheels for fun.. well the ones that fit
Work: VS-KF 18x10 +13 / 5zigen: FN10R-C 18x9.5 +12
and LED upgrades
I also have my track toy, a Nissan 240sx that I am at the final stages of my 3rd engine swap. This time I have upgraded to a 1jz with a GT35R.
Still gotta a long ways to go but its mounted, and most of the HARD work is done.
for my fellow wheel fitment whores:)
18x10 +8 (5mm spacer) 225/40 & 18x12 +0 265/35
Well, I was recently driving my SC4 and all of a sudden the engine started to missfire and run as if half of the cylnders died.
i figured the notorious ingition coil since it was one of the only things i hadn't replaced
So I did the self diagnostics and these are the codes i received.
13- RPM Signal Curcuit
14- Igniter Signal
24- Intake temp sensor curcuit
31- Low air flow meter voltage
FYI: plugs, plug wires, distributor cap & rotors had been replaced prior to this problem.
So i borrowed a friends MAF, bought 2 new ignition coils and replaced them, but still not firing.
tried resetting ecu to see if i got any different codes or difference in idle.
No luck.
Is there anything that I may have overlooked, or misunderstood from the codes?
Thanks in advance for any insght
-Gary
Welcome Gary. I thought it would be the MAF, but you mentioned that. It could be the TPS, but that has a different code. What type of Plugs and plug wires do they have, OEM, Denso, Bosch?
ANy chance something is stuck in the Intake?
Thanks UCF3
i kinda needed them, so I bought the only ones Autozone had in stock. Bad Idea #1
NGK BKR6ES-11 Copper core
and the plug wires were $60..
And on that maf... I borrowed his sensor and swapped it out, I did not replace the whole MAF housing.
Intake was clean of debris, it does have a crack. But, You can't hear a leak through it.
well... It turned out that the timing belt had jumped teeth and was off timing
Thanks for all the suggestions
