KimK Posted July 29, 2008 Posted July 29, 2008 I have a 05 Lexus. Bought it new here in South Florida. Car runs great but the other day the VSC off and check engine light came on. Couldn't find anything wrong under the hood so I pulled the pos battery cable to reset it. Stayed off for a day then came back on. Also the window controls on the driver door quit working. The driver window still goes up and down if I hold the button but the other three don't work at all. Any help would be greatly appreciated.
JENunnez Posted July 29, 2008 Posted July 29, 2008 You have to reset each window. Go to the window control of each door and lower and raise it all the way. I can't remember if it's once or twice you have to do the lower and raise, then try from drivers door. You have to do this every time you disconnect the battery.
KimK Posted July 29, 2008 Author Posted July 29, 2008 Thank you. Now for the VSC and check engine lights. You have to reset each window. Go to the window control of each door and lower and raise it all the way. I can't remember if it's once or twice you have to do the lower and raise, then try from drivers door. You have to do this every time you disconnect the battery.
JENunnez Posted July 29, 2008 Posted July 29, 2008 Sorry, I'm not familiar with that problem. I'm sure someone here on the forum can help you out. Don't want to lead you in the wrong direction.
SKperformance Posted July 29, 2008 Posted July 29, 2008 needs a scanner , go to auto zone for a free test.
