tjlazer111 Posted July 22, 2008 Share Posted July 22, 2008 Just got my IS350 a couple weeks ago and it drives nice. But I noticed the car pulling a little to the right when I'm braking. It doesn't always do it, but its noticeable when it does. I've never owned a car with lower profiles tires, so I'm just wondering if that's normal for a car with 18" wheels, because it's gripping all the grooves in the road. Or do I have a minor alignment problem. Any info would be appreciated. B) Quote Link to comment Share on other sites More sharing options...
PA350 Posted July 22, 2008 Share Posted July 22, 2008 Just got my IS350 a couple weeks ago and it drives nice. But I noticed the car pulling a little to the right when I'm braking. It doesn't always do it, but its noticeable when it does. I've never owned a car with lower profiles tires, so I'm just wondering if that's normal for a car with 18" wheels, because it's gripping all the grooves in the road. Or do I have a minor alignment problem. Any info would be appreciated. B) It's not "normal" under any kind of barking. Assuming you are on a flat and level road you should brake in a straight line. It's probably one of: * uneven wearing of pads * indicator of a caliper issue (either side). * brake fluid / air in line In any case, certainly a dealer warranty issue. Quote Link to comment Share on other sites More sharing options...
terry993 Posted July 22, 2008 Share Posted July 22, 2008 First check that tire pressures are at recommended levels, and especially the same L to R in front and rear. Quote Link to comment Share on other sites More sharing options...
Lexusfreak Posted July 22, 2008 Share Posted July 22, 2008 First check that tire pressures are at recommended levels, and especially the same L to R in front and rear. ^ Agreed. Quote Link to comment Share on other sites More sharing options...
tjlazer111 Posted July 24, 2008 Author Share Posted July 24, 2008 Thanks everybody. I'm taking it in to get it checked out. Appreciate the feedback. ;) Quote Link to comment Share on other sites More sharing options...
