Everytime i turn on my car, the air vent goes to recirculation mode autmatically, even if i don't turn on the fan. It keeps doing , no matter if the fan is on or off. S o now i have to manually switch to outside air. Is there a way to keep outside air on every time i turn on the car?
Mine does the same thing. Probably the default mode that the controller is programmed to do.
I believe If the outside temp is outside the range of the climate control settings (hot or cold), then the default setting is to recirculate.
Is it set to Max Cold, and are you pressing the Auto Button while in max cold?
If they are set for max cold and Auto adjust the temp to Max Hot anything higher than 70; it should from recirculate to Circulate. If not I'm in the same boat.
