90LS400Lexus Posted December 13, 2003 Share Posted December 13, 2003 I had new rear struts installed on my 90 LS400. The car had 4-wheel alignment 6 months ago. Since I had new rear struts installed- do I need to have my car re-aligned? Thanks. Quote Link to comment Share on other sites More sharing options...
Lextech2k3 Posted December 13, 2003 Share Posted December 13, 2003 if you had it done at a dealer.... I believe we do that automatically. i can't remember if those tied into the alinment on that year.. sorry i couldn't be more help Quote Link to comment Share on other sites More sharing options...
90LS400Lexus Posted December 13, 2003 Author Share Posted December 13, 2003 Thanks. Actually, I had them replaced at an independent repair shop- where I have taken my cars for a while. I never thought to ask them about the alignment. I am really concerned, as the car has almost brand new $450 tires on it and I do not want to ruin them. Thanks again. Quote Link to comment Share on other sites More sharing options...
jdmparts_guru Posted December 13, 2003 Share Posted December 13, 2003 a rear alignment is ofcourse always better, and that also includes for your front. Theoretical you need to check alignment periodically, and since you changed your tires also in front, the front has been changed as well. However, most people (and most shops) do not do the alignment, since it requires expensive equipment and time/effort. Also, you did not lower your car, so most likely your car will be fine (i.e. within the acceptable range). An alignment is very important/must if you lower your car. Quote Link to comment Share on other sites More sharing options...
CanadaCraig Posted December 13, 2003 Share Posted December 13, 2003 Don't put yourself though this. Get another alignment done. If you're anything like me - you'll just worry about it until it IS done. Craig!! :) Quote Link to comment Share on other sites More sharing options...
doiturself Posted December 13, 2003 Share Posted December 13, 2003 Depend on your vehicle, if your car is rear wheel drive then no rear alignment. The rear is fixed, there is no adjustment there. The only car that needs a rear alignment is an All Wheels drives vehicle. Quote Link to comment Share on other sites More sharing options...
SRK Posted December 14, 2003 Share Posted December 14, 2003 Doiturself, do you own one of these cars? If you do, get under the rear axle sometime and note that both the upper and lower control arm mounting bolts incorporate eccentric adjusters. The rear axle, which is independant, must be adjusted for camber and toe-in. All wheel drive has nothing to do with it. Quote Link to comment Share on other sites More sharing options...
90LS400Lexus Posted December 14, 2003 Author Share Posted December 14, 2003 Thanks for all of the replies. I think I will call the repair shop Monday to see if they did an alignment, or if they recommend that I have it aligned. It just shows on the receipt from back in June, that the rear struts, all brakes, and 4 tires were replaced, as well as a 4-wheel alignment. I was assuming they did the alignment because of the new tires that were installed. Even though I only had new rear struts installed- the drive home that night- the steering did not seem as responsive as before, unless it was my imagination. I have not driven it since then, but I am going to drive it tomorrow and see how the steering feels. Another strange thing, was that when I got home and shifted it into "PARK"- I noticed that the idling was a little higher than it has been. Normally- it is around 600-700 in park and that last evening- it was idling at nearly 1000 rpms. Is it possible that when replacing the struts, that the battery had to be disconnected and the computer needs to reprogram? I do not understand why it was idling fine before and now the idle is high- just after it leaves the shop. I am going to drive it around tomorrow and see what it does. Maybe it is just where the engine was not fully warmed up, as I live fairly close to the repair shop. Thanks again. Quote Link to comment Share on other sites More sharing options...
Lextech2k3 Posted December 14, 2003 Share Posted December 14, 2003 i wouldn't worry about that idle man...that's pretty normal right when you come out of gear....and no you don't have to disconnect the battery to do struts....that would be pointless The rear is fixed, there is no adjustment there.The only car that needs a rear alignment is an All Wheels drives vehicle. ok i'm sorry but what kinda idiot are you doityourself? have you not ever heard of fully independant rear suspensions? (they've only been in comon use since the 60's) Quote Link to comment Share on other sites More sharing options...
Lexusing Posted December 14, 2003 Share Posted December 14, 2003 Lextech is funny!!! "ok i'm sorry but what kinda idiot are you doityourself?" :chairshot: Quote Link to comment Share on other sites More sharing options...
doiturself Posted December 15, 2003 Share Posted December 15, 2003 Lexusing, Are you here to judge on people? Don't be a jerk here. If you don't like it, just keep your darn mouth shut.... where is your maner? Quote Link to comment Share on other sites More sharing options...
SRK Posted December 15, 2003 Share Posted December 15, 2003 Actually, we are all here to advise each other. Accurately if possible. Quote Link to comment Share on other sites More sharing options...
Lexusing Posted December 15, 2003 Share Posted December 15, 2003 Take it easy doiturself......I am not here to judge anyone......just to learn and better myself. Sorry if I *BLEEP* you off.... ;) Quote Link to comment Share on other sites More sharing options...
90LS400Lexus Posted December 15, 2003 Author Share Posted December 15, 2003 i wouldn't worry about that idle man...that's pretty normal right when you come out of gear....and no you don't have to disconnect the battery to do struts....that would be pointlessThe rear is fixed, there is no adjustment there.The only car that needs a rear alignment is an All Wheels drives vehicle. ok i'm sorry but what kinda idiot are you doityourself? have you not ever heard of fully independant rear suspensions? (they've only been in comon use since the 60's) Thanks. I drove the car today on a longer trip and the idle was back down- even when placed in "park". I guess it was where the engine was not fully warmed up on my short trip back home. Also- I did not think that the battery would have to be disconnected for rear struts, unless something electrical had to be removed when the rear seat was removed- such as speakers. I would still like to know what all they had to remove to change my rear struts. I have heard that only the rear seat has to be removed, but then I heard that the rear package shelf also had to be removed. I would think that a lot of parts would have to be removed if the package shelf indeed had to be removed. If it did have to be removed- wouldn't all of the "C" pillar trim have to be removed, or will the package shelf come out without removing that? I am just interested to know what all they did to the rear interior of my car while changing the struts. Thanks again. Quote Link to comment Share on other sites More sharing options...
