buckstr Posted December 12, 2003 Share Posted December 12, 2003 I've recently purchased an LS400 and want to change my oil. My service tech said to take the two bolts off on the palstic panel under the car, I did so but still can't see the filter. Does the car need to be jacked up in order to get to the oil filter? Quote Link to comment Share on other sites More sharing options...
michaelsn Posted December 12, 2003 Share Posted December 12, 2003 I have a '93. If you have a '90-'94 then it'll take more than 2 bolts to get to it. Take off all the bolts and screws that attach the plastic cover under the engine then you will see the filter. I didn't even have to jack up the car. Quote Link to comment Share on other sites More sharing options...
obergc Posted December 13, 2003 Share Posted December 13, 2003 The filter is on the left (drivers side) of the engine and I think a lot of guys try to just remove a couple of bolts holding the plastic pan on because it's a lot easier then removing the entire pan. That's why my plastic pan had cracks running through several bolt holes. If you want to save damaging your plastic engine under cover, I would take the time to remove all the bolts on the left side of the engine for sure. A good jack and jack stands make the job easier. Curt Quote Link to comment Share on other sites More sharing options...
Lextech2k3 Posted December 13, 2003 Share Posted December 13, 2003 ok i work for lexus and do this daily....and i don't damage a thing! the two bolts are at the back of the under guard on the driver side....there is even a slit in the guard so you can fold the flap back....the filter is about an oil cooler line and can be a little tricky to see from the ground i'd bet...the easiest way to get that flap out of the way is take a pair of visegrips and clamp it in the folded possition..this free's up both hands to worrk..also you should replace the drain plug gasket at every oil change.... Quote Link to comment Share on other sites More sharing options...
99lsguy Posted December 13, 2003 Share Posted December 13, 2003 Lextech2k3 is correct, At least my 99 is this way so 98-00 must be identical. The cover is designed to be flipped back after removing the two bolts. Quote Link to comment Share on other sites More sharing options...
Lextech2k3 Posted December 13, 2003 Share Posted December 13, 2003 all of The LS400's are like that..even the 430's are like that Quote Link to comment Share on other sites More sharing options...
99lsguy Posted December 13, 2003 Share Posted December 13, 2003 Even the 90-94's? Quote Link to comment Share on other sites More sharing options...
Lextech2k3 Posted December 13, 2003 Share Posted December 13, 2003 ALL OF THEM Quote Link to comment Share on other sites More sharing options...
99lsguy Posted December 13, 2003 Share Posted December 13, 2003 I thought that would be your answer.. Now on to the INTERFERENCE, NON-INTERFERENCE TOPIC... I await your posts..... Quote Link to comment Share on other sites More sharing options...
