First Sc
jdish
Man am I happy I found this site. I just purchased a pretty decent 93 SC400 at a price I don't want to brag about. I have noticed several things that I want to address as soon as possible. First the steering seems to have some play in it, it takes about a quarter turn sometimes to catch in a curve, it's a little nerve wracking. Second it seems to have an oil leak somewhere in the middle, haven't been able to get under it yet. Third it seems to run great and then it will Shudder for a while before clearing up. I had to pull the fuse for the dome lights as it was draining the battery, haven't found the short yet but I did notice that when it was in the steering wheel would only go back and forth and not up or down. Other than that I LOVE THIS CAR! Oh, I need to find a manual. Any help is most certainly appreciated.
Jdish there is nothing like a Lexus! Anyway use the "Search Forum" ( bottom leftof the main page) and type in Manuals. You will find a number of suggestions in the Forums!
Good luck
Thank You!
Good luck
Thanks, I will have to check that. I just found that I have an oil leak behind the balancer and I have been losing antifreeze but cannot find where from, I am assuming the water pump. It has not overheated and nothing in the oil thank goodness.
